Folks have complained that the 10 point on the vt50 doesn't smooth between points as well as it ought. So that you can get all 10 points very close but observe color temperature variations on a gradient ramp in between the 10 points.
What I decided to try is to do the 2 point grey scale using 25 and 85. I can sacrifice a bit of accuracy at 30 and 80 since it's easier to touch them up with the 10 point. I'm not sure how clever an idea that is, but you might want to try it if it makes sense to you.
