Originally Posted by Oh2Smooth
Yes, in control cal, whatever settings are currently visible in the controlcal screens (either through you doing a "GET ALL" from your TV, or typing them in manually) then if you go to File->Save settings, it will save an xml file locally whereever you specify which makes it easy to archive, send,edit settings.
Similarly, when you receive or want to retrieve older settings, you go to file->Load settings and retrieve the settings and then "SEND ALL" to you display to make them active.
Here ya go!
ISF Day Settings.xml 3k .xml file ISF Night Settings.xml 3k .xml file
I may grab a report after the Husky game.
