AVS › AVS Forum › Display Devices › Display Calibration › S&M Clipping Test Pattern Levels
post #1 of 30
Does anyone have information regarding the RGB (count) levels of the 4 clipping boxes for the S&M Clipping Pattern?
It has the White/Red/Green/Blue dual nested boxes. What is the difference between the left and right halves for each color? Are they all supposed to be visible? Or is a subset sufficient?
A nice B/W outline picture with numbers would be nice. I'm surprised that S&M doesn't have it in the Help on their disc on in the print documention.
post #2 of 30
A nice B/W outline picture with numbers would be nice. I'm suprised that S&M doesn't have it in the Help on their disc on in the print documention.
I made this graph for me before some years to fugure out the RGB value of each box.
post #3 of 30
I prefer the AVS pattern, RGB High Clipping since it shows levels below and above 235, letting the user decide how much WTW headroom they want.
Similarly, the contrast patterns on Disney WOW and DVE HD Basics allow you to set just a little WTW headroom if you want as opposed to going all the way up to 254 (however, these are white only).
post #4 of 30
They are all suppose to be visible, and unless you have projector on an over-sized screen, there is very little reason not to follow this guideline.
post #5 of 30
I prefer my disk pattern, it shows levels 230 till 254 with flashing or static option, the clipping of Secondary Colours also.
post #6 of 30
If the R, G, and B channels show no clipping, can there still be clipping on the complimentary colors?
On a side note, it would be nice if such a pattern could be added to the AVS disc.
post #7 of 30
Yes, it can be possible, Secondaries have higher luminance.
post #8 of 30
Ted where I can get your advanced calibration disk?
Thank you very much in advance
post #9 of 30
Thank you for your interest, this Advance Calibration Disk Project is personal, i have no plans to release it, i hade it for my calibrations only, i used THX,ISF etc. logos without any permision etc.
post #10 of 30
I like chaps 83 & 85 - They could help detect screen uniformity issues.
post #11 of 30
I made this graph for me before some years ago to figure out the RGB values of each box.
I’m not sure if you’re familiar with the old US TV series “Raymond”, but in the words of Frank “Holy Crap!” Your response is excellent! I thought someone might have had the same question about that Test Pattern, but you took the thought about 87 times farther than I was thinking. I hope Spears & Munsil (as well as other test disc people) take note about complete documentation. Thank you! Or σας ευχαριστώ.
The reason I asked this question is that I have been trying to diagnose some color problems with my Sony BDP-s390 player and a Panasonic 42PZ85 and Westinghouse VR-3730 HDTVs. I originally noticed poor chroma alignment with the YCC=4:2:2 color output to the Panasonic plasma TV. Basically, following S&M suggestions for performance evaluation I found that the RGB color output to my TVs improved chroma alignment and gave me the best Chroma Burst and Chroma Zone Plate Test Pattern results. I improved the picture quality of both TVs or so I thought.
While doing research for this problem I came across Chris’s (http://www.avsforum.com/avs-vb/showt...3#post22012693) work on a problem with the Sony S390 RGB output exaggerating GREEN output and clipping my TVs. So, I needed to look for color clipping levels in YCC=4:2:2 and RGB outputs for my displays. The S&M clipping display indicated a problem but I could not interpret the results without knowing the levels in the squares being show.
BTW, I noticed in the Right square the outer to inner squares go from 239, 254,244,251,247,239. Is the 244 square correct? It starts decreasing then increases for the single square then decreases toward the center low of 239. The count order looks funny (not monotonic)?
NOTE: This Chart was corrected by ConnecTEDDD in this thread below.
post #12 of 30
Plasma54321,
It sounds like you're running into the same issues with the RGB HDMI output that I am on the Sony players. There's a fairly in-depth and still on-going discussion about it here as well...
http://www.avsforum.com/avs-vb/showthread.php?t=1406044
My tests (and Chris's) with similar patterns indicate that the Sony S390 and other recent Sony players are pushing green and also clipping it at about 92-93% stimulus in RGB HDMI mode. I can't really tell what's goin on in the WTW range though because I don't have good tests for that yet. So I'd be interested to see what your findings are, if you can check what's going on in the "above video white" range in both the RGB and YCbCr HDMI modes.
Feel free to try the PNG clip test I posted there as well.
post #13 of 30
I see from your link above that there may also be a firmware fix for this in the works, which would be helpful.
post #14 of 30
Where find Ted`s advanced calibration disk?
post #15 of 30
As he mentions, he made it for himself and doesn't distribute copies.
post #16 of 30
Bad news!
post #17 of 30
Plasma54321, Thank you for noticing that, i have just checked today using my VideoEQ all levels from 235-254 one by one. Previously posted Graph had some errors, i made that graph at 2010, i don't remember what went wrong, its been a while. I have updaTED my graph with corrected values for each box, i have double check each value.
(Plasma54321, please replace with the new graph picture your quote please.)
post #18 of 30
All these usefull clipping patterns are good to prevent the Color Clipping but if you need the correct luminance level for each level above white (and you are patient), you can use the VideoEQ to make these custom levels like my attached workflow using CalMAN + AVFoundry LUT Builder for controling the RGB Level + Luminance Level for each step above white. (below white, near black etc. also)
post #19 of 30
Thanks, again for the clipping diagram correction and update. I checked this pattern again this morning. Your latest data seems to be right. I only can observe the relative brightness of the squares on my display. This information really should have been in the S&M documentation somewhere.
I was wondering how you measured the S&M Clipping pattern. Pretty slick how you used the VideoEQ box and dropped the squares level until you found the equivalent interperlated value for the disc. That must have been tedious!
... need the correct luminance level for each level above white (and you are patient), you can use the VideoEQ to make these custom levels like my attached workflow using CalMAN + AVFoundry LUT Builder for controling the RGB Level + Luminance Level for each step above white. (below white, near black etc. also)
That little VideoEQ box would be nice, but for right now I just have my basic TV controls to fix (or not) any problems. Maybe some day!
Thanks, again.
post #20 of 30
Clipping Pattern M2TS file from the disk has been examined and checked, it has the same value numbers also.
post #21 of 30
Even if you have no plans to release it, can you give an overview what patterns you created and which tools you did used?
And most interesting would be which of your own patterns you find the most usefull.
post #22 of 30
I love reverse engineering.
post #23 of 30
Thank you for your interest but it will be a huge & meanless spend of my free-time to answer all these questions about how-why made each pattern and fully discribe how to use each one-it's purpose, to kindly answer each user question and discuss for something that will never come out.
I made this disk only for me and i will never release it, i used some patterns and logos without permision etc.
Easily i can remove that logos and patterns i have no rights and release the others but it's not at my future plans.
There over 150 patterns, take a quick preview of some chapters.
post #24 of 30
Greatest!!!
Can you give an overview which tools you did used?
Where did patterns?
post #25 of 30
Greatest!!!
Where did patterns?
Photoshop+CorelDraw for Patterns.
Authored with similar method as AVSHD disk created.
post #26 of 30
Super!!!
Only Photoshop or only CorelDraw not enough?
post #27 of 30
Super!!!
Mostly CorelDRAW.
post #28 of 30
Thanx
post #29 of 30
Damn, Ted, I'm floored. The only things missing are Color Girl 1 and Color Girl 2 from the Qtec Hi-Definition Reference Disc.
Oh wait, I already have those........ lololol
post #30 of 30
This post really should be saved as a sticky. It's an excellent reference to what a complete set of HDTV test patterns should look like. It can give all the DIYers an example of how a test pattern disc should be. Maybe someone can even come up with something that Ted doesn't already have? Or not! Bravo, Ted!
