AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The SuperNoVA Theater - Planning & Build
The SuperNoVA Theater - Planning & Build - Page 3
post #61 of 95
Well, not much new to report. I have, however, slightly revised the floorplan. This makes the theater 14' at the narrowest part. I think it will also feel more open when seated.
Basement-final_1.png?psid=1
Basement-final_2.png?psid=1
post #62 of 95
Well, just trying to keep this out of the archives. Other things have been taking up my time. On the bright side we just got a minivan so hauling stuff won't be an issue!
post #63 of 95
No progress. Bah humbug. I am slowly but surely clearing out the area though, so I should be able to start trying out floor plans with masking tape.
post #64 of 95
I've been thinking about seating. I'm contemplating alternatives to dedicated theater seating which might make the room a little more versatile. Does anyone know of any alternative seating styles which can still allow for a decent theater experience for around 8 people but can then be reconfigured for other uses when not watching the screen (such as playing cards, for example)? I have room in the rest of the basement for some lounge seating but I thought it would be a nice bonus if I could make the theater room a little more versatile.
post #65 of 95
No problem.
Is your "slightly revised floor plan" flipped 180 degrees to the original? I like it.
post #66 of 95
Yeah it's just flipped 180 degrees so the seats are against the smaller wall. I know you were joking about the folding chairs but some nicer folding chairs might be a viable way to use the space for more 'socially friendly' seating when nobody is watching a movie.
post #67 of 95
I've been to your place and from what I recall you walk through lot's of socializing space upstairs, then afer getting downstairs a large open space for socializing before you get to the back room with the planned theater. Just how much socializing space do you need? Get on with it and build a nice theater already. NoVa doesn't have enough.
post #68 of 95
LOL, yeah there is plenty of room in the rest of the house, which is why it would just be a bonus. But yeah, it's purely a furniture decision, won't change the layout of the room so I still have plenty ways to go before I make that decision.
post #69 of 95
Socializing is chairs in a circle, standing around a kitchen island, or surrounding a bar. None of those take place in a theater where you put chairs facing the screen and you want people to come in, sit down, and shut up.
post #70 of 95
Well I was thinking it would be nice to be able to watch football games with some friends in the theater as well, which is probably a bit more social of an activity compared to just watching a 2 hour long movie. It's not as high of a priority though.
post #71 of 95
The time has finally arrived! I've cleared out the stuff in there by creating more storage in other areas of the house. This means the size of the closet isnt's as huge of a concern. I laid down the floor plan with chalk and it looks good. Now it's time to start figuring out what materials to order...any suggestions on some good threads to help me with that?
post #72 of 95
Hopefully I'll start framing pretty soon! So I have some questions:
1. Soffits - I guess the one soffit on the back side where I have ducting and piping will have to be soundproof. However, for the rest of the soffits, should I do those after the room is drywalled?
2. Isolating the ceiling - Can I mount clip & channel right onto the ceiling joists? I will be using two layers of drywall. Can clip & channel handle that weight?
3. When I isolate the framing with RISC clips, I can mount the drywall directly to the studs, correct?
4. Does my plan to isolate the closet look OK?
5. I like the look of sconces. However, I guess this is a soundrpoofing nightmare. The only way to do sconces is with columns, right?
For reference, here is how I was going to do the soundproofing. Blue is going to be clip & channel, and green is going to be isolated framing with RISC clips. Keep in mind the stage and seating has been flipped 180 from this diagram.
post #73 of 95
1) yes build remaining soffits inside the drywall bunker
2) yes just follow the spacing recommended by Ted at Soundproofingcompany.com for two layers
3)yes
4)yes, you could be more aggressive to keep sound out of the closet by making it a blue wall, but then I think the closet may act as a buffer of sorts to the rest of the house.
5)Not really, there are work around solutions. Putty pads on the electrical boxes is one, Part of the answer is dependent on what kind of wall treatments you plan for the sconce locations. You might be able to use surface mount pancake boxes.
post #74 of 95
So here is the existing framing on the wall that I share with my neighbor. It looks like it is already isolated from them, right? However it looks like I will still need to use clips & channel here, since it's not isolated from the framing above the house. Otherwise the sound can flank up into the upper floors.
Also, I've outlined where the closet is going to go.
Yeah, Big to be honest I haven't really decided on a design or style for the theater yet. I've come up with the "bones", and I figure none of my lighting or wall treatment decisions will impact how I put up the framing.
post #75 of 95
Fellow NoVA builders: I am going to follow the instructions for spacing clips according to the guys at The Soundproofing Company, which means that the IB3 clips to attach my framing to the ceiling will be 48" apart. For those of you who used IB3 clips for isolated framing, was that sufficient to pass inspection in Loudoun County?
Another question...I have two isolated walls that are going to be next to the foundation. They are going to be about 1" away from the foundation...can I attach them directly to the foundation with an IB3 clip? Or do I not need an IB3 clip, just a regular metal bracket? Or should I not anchor them to the foundation?
Also is an IB3 clip strong enough to hold up the soffit in the back where I have to build around the ductwork? The soffit instructions from the soundproofing co. recommends using a furring channel to hold the soffit up.
Edited by ozziegt - 3/17/13 at 8:57pm
post #76 of 95
The thing about inspectors is often what they don't know they will make up. If he wants more clips than add more clips, They could disappear the day before you drywall. The sticky item about decoupled theater walls and inspections will be dealing with the particular inspectors interpretation of the firestopping needs between the walls and the ceiling joists. Hopefully you get a guy who is happy with some mineral wool (Roxul) stuffed in the gaps.
Yes you can use IB3 to attach to concrete but given the choice I would go to the wood joists if possible. Concrete is an excellent sound conductor.
On the soffit you have to build. I build the walls and ceiling first as close to the ducts/pipes as possible without touching, making sure there are clips and channels where you need to anchor the soffit. Drywall the room first then build the soffit hanging off the drywall and channel. The result will be a decoupled soffit. Hanging framing for a soffit off of IB3 clips is something that you could do, you would need to check the load rating of the clips and do some calculations of the estimated soffit weight to determine the number of clips.
Edited by BIGmouthinDC - 3/18/13 at 6:01am
post #77 of 95
So I spent last night staring at my diagrams and I came to this conclusion: The closet wall, the back wall (where the soffit will go), and the far wall are all isolated framing. So if I attach the soffit to those, the clips don't have to hold a whole lot of weight because the walls will be taking most of it. Also if I attach the soffit to the isolated walls, the soffit will be isolated as well. The only trick is attaching the soffit to the ceiling, which is where the IB3 comes in. I understand your approach as well...do you think one is better than the other? One thing to keep in mind on the back wall behind the seats, there isn't going to be clip & channel since it is an isolated wall.
post #78 of 95
I'm in Loudoun and I didn't have any issues with the clips or clip pattern. I think by now, the Loudoun inspectors are pretty used to these home theater builds. I kind of found that they come in, look around and first asses the quality of what they see and based on that decide whether they need to take a closer look and be more picky about things. The only two issues I had with the plumbing inspection was where I tapped into the main drain with a rubber Tee, which is not allowed and he saw that FIRST thing, so he took a pretty good look around at the rest of the plumbing. Then he saw that I wasn't using the correct fitting for the shower head. Neither turned out to be a big deal, but scheduling them back in was pain. The only HVAC issue was that I didn't attach the boots to the framing. Electric, the only problem was that I didn't know that you had to use copper crimp connectors on the ground wires. The framing passed on initital. The guy made one comment about getting the "framing crew" to do something, so he must of thought it was a pretty profesional job. The insulation took about 2 minutes. One look around around and he said, "I wish they were ALL this easy!"
I did have a few spaces where I attached the stud to the foundation wall using the clips.I used the Pac-Intl DC04 clips for the walls and oriented it so that the rubber grommet was against the concrete then attached the metal bracket to the side of the stud. I only needed three or four like that and I'm quite happy with the results.
post #79 of 95
It may be built in front of and not touching the common wall so in a sense you may think it is isolated, but look at the top. It is pretty well connected to the ceiling floor joists and that may be a point of vibration/sound transfer to your neighbor. With the amount of time/$ you will investing in this project I would take the two hours it would take to add clips and channel to that and any similar walls. The $ will be minimal.
Edited by BIGmouthinDC - 3/18/13 at 7:29am
post #80 of 95
Thanks Logan for the info...are the DC-04 clips the same as IB3?
Big, yes on that wall I am doing clip & channel, but the soffit I am talking about is on the other end of the room, which is getting new isolated framing on all 3 sides.
The new walls are green in this picture. Keep in mind the stage is now on the other side, but the soffit is on the left side of this picture. The blue walls are the ones getting clip & channel.
Here is a picture of the wall...you can see it's concrete on 2 sides.
Edited by ozziegt - 3/18/13 at 8:15am
post #81 of 95
The DC04 is the same basic design an the IB-3 Bracket on the soundproofing company website. I used that style to isolate all of stud walls and soffit and used the style to hold the channel for the ceiling.
post #82 of 95
DC04 Clips. Order from Bryan Pape or Ted.
post #83 of 95
What are your guys thoughts on using 2 tubes of GG per sheet vs 1?
Also: outlets. What do you guys do about outlets? I think according to my calculations I am going to to need 9 outlets....2 on the front wall, 2 on the left wall, 2 on the back wall, 1 next to the door, and 1 on each closet wall. At this point I am leaning towards just using putty pads.
Finally, acoustical caulk..necessary or not? How much to use and where?
Edited by ozziegt - 3/19/13 at 8:18am
post #84 of 95
I'd just use one tube, and no caulk. If you don't like the result you can tear the room down to the studs and rebuild.
Bottom line is you can't make a cake if you don't follow the recipe. Also you can save money if you buy GG by the 5 gallon pail. Call Ted White or John ask for the AVS/BigmouthinDC discount.
post #85 of 95
I'm already talking to John and yeah he knows I am an AVS member. He's been very helpful. I just don't remember anyone ever mentioning using acoustical caulk in the build threads that I have followed. A lot of talk about GG but not much about GG caulk.
There is a member on here who was advised that 1 tube of GG will provide 80% of the performance of 2 tubes, which is why I am asking. He ended up with about 1-1.5 tubes per sheet and is happy with the results.
post #86 of 95
If you and your neighbor will be happy with an 80% result than use the 1 -1 1/2 tubes.
Caulk is cheap and not worth debating. There will be open gaps at outside corners, ceiling wall intersections, at the floor, and around electrical boxes (even with the putty pads). You want to fill them up.
post #87 of 95
I would say most builds use the caulk, but it's only mentioned in passing. It's one of those things that if you're going to be using GG, you might as well be using the caulk.
post #88 of 95
Yeah, seems like it. I'm sure John will help me figure out how much I need. I just wasn't sure if I needed it between joints in drywall panel. I'm sure he will advise me, he's done a pretty good job so far.
post #89 of 95
I'm getting pretty close to ordering the soundproofing supplies. Now I need to get the building supplies. Where is a good place to go in the NoVA area? Preferably something close to Leesburg / Ashburn.
post #90 of 95
My drywall source is Allied building supply in Leesburg, I also like their price on Grabber brand drywall screws. There are screws for metal channel and other ones for wood, They also stock the 25 ga metal hat channel. If you talk to Jimmy tell him I sent you.
