AVS › AVS Forum › Audio › DIY Speakers and Subs › Scan-speak D3004/6600 tweeter has faint distortion sound, is it toast?
post #1 of 4
I have a pair of speakers with the D3004/6600 tweeter and one of them now has a faint distortion sound that sounds like white noise. Is it toast? I've had the speakers for a long time now but wondering if there is anything I can do or do I just have to bite the bullet and buy another tweeter? Crazy how this tweeter is still over $200.
post #2 of 4
Are you sure that it is the tweeter, and not the source or amp?
post #3 of 4
I switched the speakers around and the distortion is on the same speaker. Also tried other small speakers I have and they don't have the distortion. All was done with the same source and amp.
post #4 of 4
I'd swap the tweeters to eliminate all of the wiring, crossovers and connectors. If the known good one sounds bad in that cabinet you know the problem is elsewhere.
