AVS › AVS Forum › Audio › Home Theater In A Box › Latest Costco Blu-ray/HTIB: Samsung HT-EM54C
post #1 of 5
Yeah, there are problems. First the good:
1) Excellent Blu-ray player with a better than decent feature set.
2) Great connectivity options, WiFi and internet actually work.
3) 5.1 sound is about as good as your going to get at this price level ($369.00)
The bad is related to internet applications in Smart Hub. Everything worked out of the box three weeks ago, but subsequent online s/w updates have broken the Web Browser app (an absolutely essential feature) and several others. When I try to start them I get the error message: "You do not have enough memory to download this application." Some apps like Pandora, Vimeo and YouTube are unaffected, but without the Web Browser the system isn't very useful, since my TV has all the "standard" applications built-in as well.
Another big annoyance is lame remote keyboard support. Most of the standard apps don't support keyboard character entry, so despite buying a keyboard you're still stuck with picking letters off a menu, except that now you can use keyboard arrow keys to move around a bit quicker.
Anybody else got this thing? Despite these issues I may keep it as I don't think I could get better Blu-ray/sound for the price. But I had hoped the unit could make a dedicated PC for internet video unnecessary and right now it sure doesn't do that. I'm waiting to see if Sammy can get the thing fixed in the next s/w update.
post #2 of 5
I saw these for sale at Costco for $329, any thoughts?
post #3 of 5
I think you'd be better off purchasing a good HTiB (Yamaha, Onkyo, etc) and buy a separate BD player with built-in WiFi. The more stuff you pack into a single unit, the more apt you are to have problems. Besides, the all-in-ones tend to have passive sub-woofers (derive their power from the BD player) as opposed to an active sub-woofer (separate power supply). Web browsers on these units can be a problem as you have seen but if you're intent on surfing the web on your tv why can't you connect your laptop?
post #4 of 5
Yeah after some more research I'm going a completely different direction.
post #5 of 5
Any new comments on this HTIB, good or bad? I need a new unit in our RV, saw them in Costco today for $299.99. Looking at either this one or a Panasonic SC-BTT490 from Best Buy. Also, is this unit the same as Best Buys Samsung HT-E5400ZA?
Won't be using any of the internet features, just movie and Ipod playback.
Edited by jkhome - 1/3/13 at 11:35am
  Back to Forum: Home Theater In A Box
