This one is not brand specific, just a general question I have about how amplifiers work and to some degree how they are rated.
So, for talking purposes, let's say a two channel amp with 100w/channel output.
If, either via and internal crossover or a pre-amp, frequencies below 80Hz aren't fed to the amp (as we would see in a usual .1 setup with lower frequencies sent to a sub), does the full 100w go into that 80Hz+ range, or does the power output actually get reduced because part of that 100w only applies to those lower frequency ranges?
To put it another way, does it really make sense to set that 80Hz cutoff in the amplifier because that power that wasn't used for the low frequencies will now distribute over the higher frequencies?
And, in a related question, say the amp is set to output full range, but the speakers connected to it only go down to 60Hz. Is the amp still putting out 100w, but it just becomes wasted because the speaker can't respond effectively to it? Or is it more a case that the full power goes to the speaker, but it is just has such a poor efficiency below that 'cutoff' frequency, that the power doesn't produce any usable sound?
