Actually there is a benefit to mounting them this way. Just like keager mentioned it cancels out driver non linearity which will greatly reduce even order harmonic distortion. That said I'm pretty sure it's the odd order stuff that's been found to be the most audible/offensive. I did some googling for a reference but didn't find much. There's a reference at the link below under Compound ~ Push/Pull Dual Drivers but it mentions some think odd is cancelled while others think even:
http://www.danmarx.org/audioinnovation/theories.html
Here's an AVS post from a couple years back with some discussion as well (this one clearly states even and sounds pretty convincing):
http://www.avsforum.com/avs-vb/showt...6#post16482906
Here's a loose reference regarding even order vs odd order distortion in subs:
"Higher-order and/or odd-order harmonics have progressively lower allowable distortion limits, as these tend to subjectively be more offensive to the human ear than lower order and/or even-order harmonics."
Found near the bottom of this page:
http://www.audioholics.com/education...oofer-shootout
