AVS › AVS Forum › Audio › DIY Speakers and Subs › Keager's Quad RE XXX 18 Underfloor IB Build
Keager's Quad RE XXX 18 Underfloor IB Build - Page 6
post #151 of 341
Originally Posted by popalock View Post
I'll go ahead and step aside from my interest in your clone. Seems to be too much competition..haha
Originally Posted by edoggrc51 View Post
Awesome! Paypal coming your way Keager.
+1
I can get behind this! I would help me quit bugging Edogg asking him if he has his second amp every other day...lol
Originally Posted by keager View Post
Better talk to popalock before you get too excited. He was first in line by hours.
First come, first serve.
Done! lol
No but seriously, if popalock passes consider it sold.
post #152 of 341
Definitely buddy. I had to go back to the actual pm's to see who asked first. You are second, it will be a coupke weeks before I have the new one hooked up and ready to release the 14k.
post #153 of 341
So I'm going to order a 10000q clone amp soon, and I need to make sure I have connectors etc to connect from my minidsp 8x8(not hooked up yet) and my new amp. Would I be better off running 4 ohm stereo using all four channels or going 8 ohm bridged?
If I remember right the LG OEM spec sheet said you get 2100 watts @ 4 ohm per channel. I don't recall what you could get @ 8 ohm bridged, but if it's anything like the FP14K and most other amps from what I have seen then 8ohm bridged should be roughly equivalent to what you are getting at 4ohm per channel x 2.
Meaning, it's just another round about way to get the same power...
Someone correct me if I'm wrong?
I say keep it simple. One sub @ 4ohm per channel.
post #154 of 341
Sounds good. I would just need an xlr splitter so I can have two outputs from the mini dsp going to four channels.
post #155 of 341
Sounds good. You ok with this Papalock??
a 2 into 1 XLR splitter???
post #156 of 341
I just need to eq each pair of subs seperately, not each driver. Would save outputs on my minidsp that way. Maybe im describing it wrong.....
post #157 of 341
This is what i was thinking of:
post #158 of 341
Yes. Actually since i have to use bare wire to hookup to the minidsp, I'll just use a long xlr, chop off the end and then splice two ends on the amp side. I wonder if they sell bull xlr cable without the ends...hmmm. back to the drawing board.
post #159 of 341
lol! Well if you need this one let me know. Since I had that custom 4-1 splitter made it just sits in my cable box all sad and stuff.
post #160 of 341
Thats a kind offer, but I'd hate to chop up that beauty.
post #161 of 341
I'd hit that... How much did that run from BJC?
post #162 of 341
Like $40 I think it was???
post #163 of 341
Emotiva also sells splitters that work great. I have 2 of them.
post #164 of 341
I ordered the 10000q clone and a couple emotiva splitters, some speaker wire, some 12/3 romex for wiring in the 220 circuit, and a relay for mounting the amp in a closet. Hope to have the first manifold playing this weekend.
post #165 of 341
Awesome! Getting closer there brotha!
post #166 of 341
Where is the damn clap emoticon on this new forum???
Great to hear man.
post #167 of 341
How would one use these relays in a 220v application with two hot leads and one ground lead? Do you just "switch" one of the two hot wires? I have a lot of studying before I install it, but just wanted to see if anybody has done this specifically.Omron G7L-1A-TUB-J-CB-DC12
post #168 of 341
made a little more progress today. built up the joists.
post #169 of 341
Lunch break. One driver installed in the first manifold. Easy to drag to location, pain in the butt to install. i had to use ratchet straps to lift the motor so I could line up mounting holes. New amp showed up also.
post #170 of 341
post #171 of 341
haha awesome
post #172 of 341
that some good thinking tho. I love the look of their baskets, and how you can see the split-coil. awesome, I enjoyed coming home for the week that the first thing I saw when I walked through the door was a pair of those bad boys sitting on my counter-top smile.gif quite intimidating!!
post #173 of 341
Originally Posted by NicksHitachi View Post
Its more like" You know you need proffesional help when you need a hoist to lift your subs" LOL. Second driver installed. How did I know my floor jack was going to be involved?
post #174 of 341
Haha, niiiice... Man, looking great. This is definitely going to be a labor love in the long run. With your 4" peak to peak I'm really looking forward to seeing these manifolds jumping. It's going to be a sight for sure.
Have you had a chance to unbox and test your new Clone? I'm stoked for you bro!
Keep us updated throughout the weekend.
post #175 of 341
I don't have the 220 installed yet. Trying to find a hungry-looking for cash electrician to puit it in cheap.
post #176 of 341
My electrician is charging $425 to put in my dedicated 30amp circuit. I thought that was high, until I got another opinion. Turns out it's reasonable, but still a lot higher than I really wanted to pay.
Anything to hit the lows...
Edited by popalock - 6/15/12 at 5:41am
post #177 of 341
Ouch. I might do it myself if it is that much. Im tryin to find a diagram for hooking up an xlrto my mini dsp 8x8. I cut the end off and have black, white and shield. I dont see any designation on the phoenix terminal of the mini dsp. Am I missing something? I didnt see it in the manual either. I've seen it before, but for the life of me, i can't find it now.
post #178 of 341
For running a dedicated line the price depends on how easy or difficult it is to get from the panel to the proposed plug. In my last house it was easy and only cost $170 for a dedicated 30amp line but in my new house the run is much more difficult so it will be double that.
post #179 of 341
flip themini dsp over its printed on the pcb
post #180 of 341
I've been doing things the hard way my whole life. Why would I start doing them the easy way now!!??!! I swear I looked there a dozen times...oh well. Thanks!
