Originally Posted by
Zon2020
Who said anything about a "massive" subwoofer?
I meant massive as in expensive. In any case, my point was that not everybody needs to have thump and boom to watch a movie. My system can run within 3 db of reference down to 18 hz. But I personally prefer to lower the sub output. If needs be, I'd be fine eliminating it altogether. If speakers had to go, I'd drop the rear surrounds, then the sub, then the side surrounds. It certainly isn't one of the most important speakers to me.
Zon2020
Some of the best subwoofers made are small. You can buy outstanding subs in small packages... ...be "clean", and produce accurate sound at sufficient SPLs down to at least 25 hz.
Point me to a small subwoofer that can keep a clean, linear, in-room output to within 3 db of reference down below 25hz without having to muddy the output by corner loading it. Tested output please, not manufacturer's trumped up marketing documentation.
Zon2020
And the center produces all the main dialogue and over 50% of the total movie soundtrack content. It's unquestionably the most important speaker in video surround sound. And that is unaffected by room layout or personal preference. More important content comes through the center than from any other speaker. It's the most critical. Yes, if you have to skimp, you can skimp on the fronts and surrounds.
I disagree. Personally, I see so many people's setups, where they have the center speaker sitting above or below the screen, often a couple of feet off axis from the mains let alone the height of the listeners ear, and just think how horrid the imaging must be. Yeah they say to themselves, the sound is nice and clear, and it seems to be coming from the direction of the TV. But they have little idea how bad it still is, all things being equal. Or how much better it could be with judicious use of treatments and/or speaker re-positioning.
Honestly, for most people, assuming they sit inline with their TV and not decidedly off axis, the compromises they must make to place their center speaker make it wasteful. They should put that money into better quality mains and just run a phantom center. Yes, the center speaker does help if you are sitting significantly off-center, but then the whole audio (and visual) experience is just compromised and at that point the center channel is little more than a band aid anyway.
In any case, all I said was that your opinions are fine, as long as they are kept in the context that they are just opinions. There's more than one way to setup your AV system.
-Suntan
