AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › My Dune Prime is acting up...
post #1 of 18
I'm constantly getting "Error: Format is not supported" when trying to play basic MKV files. I'll try with my Popcorn Hour or computer and the file plays fine. What is going on with Dune lately? Is this player falling apart on me, because this just starts to happen all of a sudden.
post #2 of 18
Can you post a Mediainfo file output on the mkv in question?
post #3 of 18
Did you happen to use MakeMKV?
post #4 of 18
This can't be. I was under the impression that the Dune players were perfect! /snark off
post #5 of 18
Any changes to your supported video resolution settings on the Dune?
post #6 of 18
I just formatted my computer so I'm in the middle of reinstalling everything. The MKV files that I couldn't play I will get a mediainfo query on them and post it up. Like I said, I was able to play them with my Popcorn and Computer. It is not the norm, that is why I even posted something. Usually the Dune has no problem at all.
post #7 of 18
Very strange here. I'll get not supported file a couple of times and if I keep hitting play on the same file it will eventually start to play. I play %100 off my unraid server and I just upgraded to the BETA RC3 version which I think is the problem. Soon as I move/copy the file to an external drive or locally to the Dune player, the file plays %100 of the time just fine. Solving issues like this with unraid is very difficult.
post #8 of 18
Well here is an MKV file that my Dune cannot play. It plays just fine on my PopcornHour. Here is the mediainfo. Maybe some experts can take a look and see something?
General
Unique ID : 225743411500101922911699503920427402759 (0xA9D4997F19308029ACEC75F0E62D8607)
Complete name : N:\\moviesdown\\Fair Game 2010 720p BluRay DTS x264 HiDt\\fair.game.2010.720p.bluray.dts.x264-hidt.mkv
Format : Matroska
Format version : Version 2
File size : 4.37 GiB
Duration : 1h 47mn
Overall bit rate mode : Variable
Overall bit rate : 5 805 Kbps
Encoded date : UTC 2011-03-21 07:17:01
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 47mn
Bit rate : 4 234 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.258
Stream size : 3.10 GiB (71%)
Title : x264
Writing library : x264 core 114 r1913 5fd3dce
Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=0.95:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=4234 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 47mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.14 GiB (26%)
Title : DTS 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 1h 47mn
Bit rate mode : Variable
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Stream size : 49.3 MiB (1%)
Title : Commentary
Writing library : libVorbis (Schaufenugget) (20101101 (Schaufenugget))
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : Bulgarian
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Chinese
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : :Chapter 01
00:05:13.730 : :Chapter 02
00:09:18.933 : :Chapter 03
00:14:47.428 : :Chapter 04
00:21:17.943 : :Chapter 05
00:27:58.802 : :Chapter 06
00:34:56.594 : :Chapter 07
00:41:12.219 : :Chapter 08
00:49:09.237 : :Chapter 09
00:54:25.804 : :Chapter 10
01:00:06.853 : :Chapter 11
01:06:55.261 : :Chapter 12
01:11:50.264 : :Chapter 13
01:17:42.824 : :Chapter 14
01:21:50.280 : :Chapter 15
01:27:16.606 : :Chapter 16
01:30:24.752 : :Chapter 17
01:37:45.359 : :Chapter 18
post #9 of 18
Not surprising. The me mode is backbreaking tesa on top of all those other options - subme at 10? and on top of all that you have 12 reference frames. Can you post a sample? I'll see if my Micca player can play it.
post #10 of 18
Yeah, the 12 reframes is what sticks out
post #11 of 18
I don't have any software that can break it up and grab a portion of it. Unless there is some really good free stuff out there? This also makes me think in making an HTPC. Since VLC and my computer can play this fine.
post #12 of 18
Just use mkvmerge, you can split files. DGSplit is another free option
post #13 of 18
To get a clean MKV, demux via MKVExtractGUI2, then remux via MKVMerge. You'll want to type in 23.976 for FPS for the video track.
post #14 of 18
Is this via network or USB attached drive. If its via network then you may want to double check your share permissions. When I get these types of errors I usually just reset all my share permissions (including all registry hacks that you may have done in the past) and check your sharing options. That usually does it for me.
BTW, I get these types of errors every single time there is a major security updates via Windows update. They seem to revert the permissions and network settings back to default and break any changes you have made to make the Dune work with Windows.
If you use unRAID then you may want to double check your permissions but I am not knowledgeable in it to say that is 100% the error with that.
post #15 of 18
The files reside on an unraid box. I changed file permissions to "777" for testing. Same result. I'm going to try and grab a piece of the MKV for others to try.
post #16 of 18
Here is the sample. It is 10MB. Let me know if your player can play it.
http://www.photopiks.com/fairgametest.mkv
post #17 of 18
I did this exactly what you said and I was able to play the file just fine. Thanks for the tip. I hope not many MKV files need this.
post #18 of 18
This was my fault. My TV doesn;'t support I think 50Mhz and I had it set to 24/50/60 Mhz. Soon as I changed it back to 24 and 60 only, it worked fine.
