Got a CLD704 from Pioneer, original owner, that seems to have stopped ejecting/loading discs. I was playing a disc last night and let it finish normally, but when I went to eject the disc, the LED display showed Open but the tray did nothing. Power cycling didn't help, nor did unplugging the unit.
I got the top off and was able to get the disc out and, gently, played around with some of the components. The head mechanism still functions normally but the spindle was stuck in the "up" position. After unhooking one of the boards I was able to get to the tray motor and discovered that it does double duty as both the tray drive and moving the spindle up and down. I manually got the spindle into the down position and then manually ejected the tray. But the mechanism will still not load the disc. I suspect the motor is dead but I'm surprised the motor would just stop functioning like that without any warning.
Anything else worthwhile trying? I doubt I'm going to be able to find a replacement motor for it-
