AVS › AVS Forum › Audio › Audio theory, Setup and Chat › New LCD tv..lost on how to hook up a surround system.
post #1 of 18
Ok, first post so bear with me. Just got my first LCD tv about 6 months ago. The audio is teeny, and i wanted something to accentuate it a little more. Nothing top of the line but just enough to fill my 1 bedroom apartment. Scouring CL I found about 2 or 3 different cheaper HTiB. ..My tv has a "Digital Audio Out" but im not sure the type of connector it takes (it looks like a spdif connector but in the manual it says Optical fiber cable..so im confused) It also has a separate AudioPC/HDMI port on the back that it refers to in the manual for sending audio to a receiver. so..idk what i need.
ok..I have a Sharp LC-32SV29U lcd tv
Here's the manual
1st choice was this Sony BRAVIA theather system.
2nd choice:
panasonic sa-ht800v
if neither would work..basically im asking what inputs/outputs would i need to look for on a receiver so that I can hear surround sound from my LCD tv.
post #2 of 18
What source(s) do you use? Cable box, dvd player, antenna tv, etc
post #3 of 18
just antenna. no satellite or cable yet...
Edit
I forgot to add.PS3 and Macbook via HDMI
post #4 of 18
ok..I have a Sharp LC-32SV29U lcd tv ((sorry cant post urls yet))
1st choice was the Sony DAV-HDX287WC
2nd choice was the panasonic sa-ht800v:
Hi CalicoNC, the Sharp "Digital Audio Out" has a coaxial connector. The "Audio PC/HDMI port is a input and not a output (mostly likey a manual misprint).
Assume you get
1st choice: connect a digital coaxial cable (like this) to Sony
2nd choice: connect a digital coaxial cable (like this) to an audio converter (like this) and then RCA audio cables (like this) to Panasonic
post #5 of 18
thanks alot yall! So basically either would work but the Sony has digital coax in and the panasonic doesnt which is why i would need the converter.
post #6 of 18
The plastic fiber optic connector is one of several S/PDIF connection types.
Get the right cable, connect it to any modern home theater receiver, and you'll be in business.
post #7 of 18
Ok so i got the concept of it...almost. Lets say I want my ps3 to output through the surround sound system. .If my ps3 is hooked into the tv's hdmi port would the sound automatically be routed to the surround sound speakers or do you have to hardwire every source you have into the receiver independently?
Im asking because in the manual for my tv, it says "Digital Audio Output is not available when using an HDMI input"
post #8 of 18
no. HDMI is a 'smart system" and will communicate with your TV before deciding what to send. Your TV is stereo, so the PS3 will send a stereo track to the TV. THere will be no multichannel info going to the TV, so it could not send it out if it wanted to.
Plus, since the TV cannot output digital, and does not have analog rca outputs for all 6 or 8 channels, it seems reasonably obvious that the tv cannot transfer multichannel to the receiver.
PS3 to receiver, receiver to TV is the way to go, generally speaking. It's not more trouble, just changes where you have the multiple connections and where you have the single connection.
post #9 of 18
ugh..so i would have to wire the ps3 through the component inputs on the back of the receiver. Which is fine, BUT..I really wanted to be able to have atleast one HDMI input on the receiver because I sometimes hook my mackbook pro up to my tv via hdmi to watch movies I've downloaded or search the web on my LCD. So this receiver wouldn't be a good idea for me to purchase im assuming.
post #10 of 18
I would definitely look at getting a receiver that does HDMI! For one its the connection that gives the best audio and video quality and its all thru one cable. For two it makes connections and operation very very easy.
HDMI out of PS3 into Receiver
HDMI out of anything else you want to hook up into receiver
HDMI out of Receiver into TV.
post #11 of 18
The only way to go with your TV is to have a receiver with at least 3 HDMI inputs and an HDMI output to your TV.
I suggest that you get the Denon AVR-1312 receiver, which is under $150 from Amazon, and then deal with what kind of speakers you want to connect to it. It will connect to anything you want (4 HDMI inputs plus component video and composite video) and feed the signals to the TV via HDMI.
For speakers, I suggest that you look at the Jamo S426HCS3 system at Amazon for $300; a very good set of speakers for such a low price IMO, and a good match for that receiver.
post #12 of 18
thanks for the suggestions. I finally understand it now. The denon seems like a good buy. The speakers may be a little out my price range lol.
Just came back from a local pawn shop and they have a Denon AVR-391 for $99. It seems like it doesn't have alot of features but it does have a few HDMI inputs. Any thoughts on this unit?
post #13 of 18
Originally Posted by commsysman View Post
I suggest that you get the Denon AVR-1312 receiver, ... It will connect to anything you want (4 HDMI inputs plus component video and composite video) and feed the signals to the TV via HDMI.
Hi commsysman, the AVR-1312 does not have Component input (but it does have S-Video input ) and this receiver will not convert analog input signal to HDMI output.
post #14 of 18
post #15 of 18
Thanks for the suggestions everyone!! I ended up going with the Sony DAV-HDX287WC. I know it doesn't have HDMI, but the price was just too good to pass up ($100). It was basically brand new. Half the speakers were still shrink wrapped and not opened. He ran into a problem similar to mine but couldn't take it back because he threw the box away. So, I figured I could do something to make it work.
As of now..
My ps3 is hooked to my tv via component. Digital coax from tv to the receiver. The audio works fine from the receiver, even though i dont think its in surround, but im okay with that.
Now hooking my Mac up is a little more challenging.
Since no "HDMI in" is on the receiver, i cant hook it up directly....so..I hooked the mac up via HDMI to the tv.. and routed the audio via 3.5mm cable from the headphone jack on the mac into the "Audio In" port on the receiver. I then switched the function to "audio" instead of "tv/video" I get audio from all speakers..(granted its not true surround sound, i dont think)
I basically just wanted to know if this was all the options I had. Is there some other way I could hook everything up? I read somewhere about an HDMI switcher but im not sure what that is or if it would apply in this situation.
post #16 of 18
any other suggestions?
post #17 of 18
Macbook -> HDMI cable -> Tv
Macbook audio -> 3.5mm/RCA cable -> Receiver
PS3 -> HDMI cable -> Tv
PS3 -> Optical cable -> Receiver
Tv -> Digital Coaxial cable -> Receiver
Receiver -> HDMI cable -> Tv
post #18 of 18
thanks Jchin, you just made me realize I have an optical out on the ps3. I didnt even notice it. Wel, i did just get it a couple of weeks ago. Thanks. I think I have found the best way to get sound out of this system. Sounds pretty good..way better than the tiny stock speakers.
Actually I just found out another breakthrough(well to me)!!! I got my MacBook Pro around late 2011, so its relatively new... to me. I just realized that the Macbook pro's headphone out jack also doubles as a s/pdif Digital Out port. So all I would need would be one of these chords and go from the audio output of the mac into the receiver's optical in. That should get me 5.1 surround sound i think.
