Ok, so it's time to buy a new HTPC. The on-board RAID Array controller in the existing one has wiped out the disks for the last time and I refuse to rebuild it again - RAID is supposed to be fault tolerant not the root cause of all disk failures.
So, what was I using?
Rendering devices?
Environment?
So why am I doing this?
So, what am I looking for?
One of the first things is upgraded audio - and this is probably too deep for this topicbut. Since the release of HD S/PDIF systems have pretty much become obsolete as legacy interfaces can't handle the bitrate and the standards mandate content protection that's not available. The industry has screwed us! The availability of HD audio has been supper disappointing and is mainly caused by the expense of developing the complex, compliant, HDMI interface. Introduction has moved at a glacial pace, some companies just gave up, and the ones that didn't want $8k and up for a working processor that can do HDMI audio so we're all paying a fortune for someone else's protection that was cracked and had become moot before the format was even finalized but I digress.
Given this though I have been torn between trying to implement HDMI audio to the processor, assuming I can even find one that's affordable, or simply go directly to balanced analog in the HTPC or externally, like a Lynx Aurora 8. I'm leaning towards analog since it nullifies the stupid HDMI issue and suddenly a whole host or processors become usable.
The current projector won't do 24p or 3D. I can't see myself ever concerned about 3D but should I upgrade the projector 24p should not be an issue.
I'm tired of Asus et al., the stuff is buggy, support non-existent, bugs are never fixed, etc., the time I've had to put into it easily cost 3x professional equipment. I'd prefer IBM, Dell, Supermicro, etc. , life is too short.
Needs to be rack mount, like to keep it around 1-2U, no more than 3U.
And I guess finally, just so I don't miss anything:
I have my own thoughts on where I'm going with this but I'm curious about people's reactions to this as It might cause me to rethink some of it.
-Ted-
- Asus A8N-E Motherboard
- AMD Athlon 64 x2 dual-core 4800+ CPU
- X2 Corsair CMX1024-3500LLPRO memory
- Nvidia GeForce 8800GTS
- M-Audio Delta 2496 digital IO
- X2 WesternDigital WD3000HLFS hard disk
- LiteOn DVDRW SHM-165H6S
- Pioneer BD ROM BDC-202
- Emacs R3G-6650P power supply
- iStarUSA D-300AS 3U rack case
- ArcSoft TMT
- Jriver MC17
Rendering devices?
- Sony VPL-VW100 front projector
- High end audio system
Environment?
- Dedicated data center
- Soundproof
- 80 Amp feeder
- 19 Middle Atlantic rack
- Dedicated 15,000 BTU/hr cooling
- UPS
- The RAID controller just trashed the disk again and I have to build something now.
- There was too much stuttering on Super 8, CPU was maxed out, had to rip the disk to hard disk as there was not enough horsepower to decode the disk and play it at the same time - existing system is under-powered.
- Currently unable to take advantage of latest audio formats, needs upgrade.
- Approximate Purchase Date: Now (or as soon as I can put a plan together)
- Level of Expertise at building and configuring a HTPC: Electrical Engineer, although the last CPU board I designed was an 80286, when I got out of the hardware business. Been running an HTPC for more than 10 years now.
- Budget Range: $4,000-$6,000
- System Usage from Most to Least Important: watching 1080p/720p form BD or HD, multi-channel, audiophile quality, audio; NO Netflix; NO OTA signals or cable; encoding HD files from time to time; networked - wired; NO gaming; surfing the internet
- Size of HTPC case: 19 rack mount, black. 1-3U, up to 26 deep
- Case Make and Model: OEM
- Optical Drive Needed: Yes, state of the art, RW, possibly two.
- Parts Not Required to buy: None
- Preferred Website(s) for Parts: None
- Country of Origin: Don't care
- Parts Preferences: Supported! AMD?... YES!, Intel?... YES!, nVidia?... YES, IBM?... YES!, Asus?... H*ll NO!
- Data Storage: In the process of installing iSCSI SAN may use Infiniband, may use Ethernet, separate interfaces regardless.
- Additional Comments: Cooling not an issue, sound not an issue. Should be low power consumption; I'm trying to lower my electric, cooling and UPS costs.
-Ted-
