When I was wiring up my room before drywall, I ran lengths of 75ohm RG6 cable - thru ceiling and wall cavities - to various places in the room for subwoofer drops.
A few weeks ago, I got my system set up and used one of these drops to add my subwoofer. The placement is completely across the room (22ft) from where my AVR and components reside in a cabinet. I added RCA plugs (RG6 connects via 2 screws) to the ends of the RG6. Everything worked fine. Until now.
I had a couple of instances where I would turn on the woofer and it would hum. I would simply toggle the main on/off switch and it would fix the problem. Then, a few days ago, the hum came back - and wouldn't go away.
On advice from a Velodyne rep on these forums, I did some troubleshooting last night, and I believe I've determined that the issue has to do with this RG6 cable.
When I connect the sub directly to the AVR (after dragging it across the room) with a boughten cable, it works fine. When I turn on the woofer when attached via the RG6 drop, it hums - even when the AVR is not on, which I think means it isn't receiving any signal.
This fact leads me to believe that somewhere in the ceiling, my RG6 cable is in too-close proximity to some Romex carrying power. Isn't this the only reason that there would be a hum when there isn't any signal coming from the AVR? Or have I somehow not correctly installed the RCA ends?
Short of pulling the cable out of the wall/ceiling altogether, I don't know how to troubleshoot this issue. And, even if I pull it out and run the same or a different run of RG6 cable back through - if the path is still the same, then theoretically I would still have the same issue?
Would running a boughten subwoofer cable make any difference here?
Really grasping at straws here to try to fix this issue.
