Hey All,
I currently have one sub in my HT, but may add a second down the road. I'm trying to investigate the best way to EQ my current sub, and whatever that method is, I'd like it to be able to separately EQ two or more subs so that I have some room to grow in the future. When I say the "best" way to EQ a sub, I'm looking for something that is reliable, relatively easy to set up, use, tweak, etc, and something that consistently gives good results to the people using whatever method it is.
I like the idea/simplicity of the Velodyne SMS-1. It allows you to manually EQ the bass curve, and displays the result of the sweeps on the screen. The downside seems to be that you can only EQ one sub, or apply one set of filters to one or more subs. Also, the GUI is outdated and there are only 8 bands that can be adjusted.
So, what other products are out there that are similar to the SMS-1? How do you guys EQ your sub(s)? If you use a bunch of different things in conjunction (aka: not a single unit like the sms-1) what makes up those systems and can you provide links to those things?
I really wish someone made a subwoofer eq that could accept up to 8 sub inputs, eq each one separately with 24 bands, and display the results on the screen!
Thanks in advance!
Thanks in advance!
but I suspect that will change soon.
