AVS › AVS Forum › Video Components › Video Download Services & Hardware › Device Comparison Chart
post #1 of 9
I didn't see this posted, but thought it warranted its own thread (vs. being buried in the Best Device thread). I think it's relatively up-to-date, but unfortunately doesn't show FPS (it's my understanding that the new Tivo does 1080p/24).
Someone put together this comparison, which I think will be handy: http://blog.streamingmedia.com/the_b...one-chart.html
Here is the direct link to the PDF: http://blog.streamingmedia.com/2012-...hart-Final.pdf
post #2 of 9
2012 Best Home Media Server Comparisons and Reviews
Digital Media Player Review
IMO, there is no best player. They all seem to have their shortcomings. One would have thought the kinks would have been ironed out by now.
post #3 of 9
It depends on your set up. I use Apple TV (the new one) and it works flawlessly. I have all my digital content in iTunes so it works well for me. I also have a Blu Ray player for when I need optical.
I used to have a Roku but converted to Apple TV because of their UI and AirPlay. I just disconnected my cable service last weekend. No regrets so far
Since I got the Apple TV a couple if months ago it is used for 90% of my content. Blu Ray is the rest.
The survey is slightly off. Apple TV does support 1080p and does stream pictures. Both are shown as missing features.
post #4 of 9
There is no player that does ALL of the content providers. The ATV3 is a nice player, my daughter owns one but she also owns the WDTV Live and the 'fat' PS3 for more content.
post #5 of 9
Does it play Blu-ray ISO or M2TS files? If so, will it pass through DD TrueHD and DTS Master Audio? Will it play WMA Lossless or FLAC files? If not then it does not even come close to being a universal media player.
post #6 of 9
I noticed a possible error on that Streamingmedia PDF. It says the WD TV Live has composite video and analog audio outputs. It does not, at least the latest version. It only has HDMI and optical audio.
post #7 of 9
It comes with a mini-plug to composite video, stereo cable.
http://wdc.com/en/products/products.aspx?id=330
post #8 of 9
I just noticed that when I was putting the box away. Looks like my old iPod in that it uses a triple-ring 1/8" plug.
post #9 of 9
Originally Posted by mproper View Post
... unfortunately doesn't show FPS (it's my understanding that the new Tivo does 1080p/24).
This is an actual weakness of the TiVo Premiere's player. It can only decode Netflix's 1080p24 video and pass it through--it cannot convert the framerate. Therefore, if your television cannot handle 24p input, it can't play 1080p Netflix as provided by the player in the TiVo Premiere (maybe some AVRs can do the conversion from 24p to 60p internally?). This would seem to be a unique hardware deficiency of the Premiere itself.
Also, because it can't do this, it always has to switch output resolutions to go to 1080p24, which takes a bit of adjustment for most displays, causing a visual "blip". Of course, if your available bandwidth to TiVo's servers is high and stable, it should only happen once.
