AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Inexpensive colored accent lighting for underneath sofas?
post #1 of 6
I want to get orange lighting to place underneath my home theater seating. I have two sets of seating, one is about 100" long, the other is about 75" long. I basically want to put out enough light so that in a darkened room, the lighting can illuminate the feet area enough so that the viewer can make his way out of the room without tripping over things. There seems to be a million options and I don't know where to begin and what the hierarchy is in terms of brightness and illumination. I've seen LED light strips, LED rope lights, cold cathode tubes, etc. What would be the most cost effective solution?
post #2 of 6
http://www.ledlightingkit.com/ I have some of their products and their customer service has been good.
post #3 of 6
I've actually used a standard under car led kit, the one I'm using right now is street glow's lightstrike kit. Has a remote control and is fully adjustable. Also nice name gundam, are you a fan of war in the pocket?
post #4 of 6
Yes I am. But my favorite has to be the 08th MS Series.
post #5 of 6
I ues a under car kit by street glow, remot controled
post #6 of 6
This place is also www.barlighting.com
I ordered some for behind my AT screen, and currently have more on the way for crown and undercabinet lighting in a wetbar. Great product.
