AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Velodyne VX11?
Velodyne VX11?
post #1 of 12
I have a basement home theater with Niles Stagefront IW2550 LCRs
http://www.nilesaudio.com/product.ph...rdcdID=FG01330
How would this Velodyne sub do for my setup? I get the impression that its too small and that this is for a smaller room.
http://www.amazon.com/Velodyne-VX-11...cm_rdp_product
By the way, I am only going to use one sub. I made the mistake of not wiring for a second sub and can't have speaker wire running across the room.
Gear mentioned in this thread:
post #2 of 12
Your gonna need a bigger boat my friend.
post #3 of 12
Recommendation?
post #4 of 12
Originally Posted by blackrain View Post
Recommendation?
What is the top of your budget?
post #5 of 12
$300-$350
post #6 of 12
For $200 till 5/21
http://www.newegg.com/Product/Produc...energy%20s10.3
Or if you can wait for it to go down to $299 again-better sub in my opinion:
http://www.newegg.com/Product/Produc...ipsch%20rw-12d
Or for $50 more than your buget:
http://www.amazon.com/gp/aw/d/B000YQ...7310732&sr=8-8
post #7 of 12
I owned the VX-10, which is pretty similar to the VX-11. I was not impressed and got rid of it a few months later. I agree with tvuong. The Energy S10.3 is a great buy at $199. For only a little bit more than a VX-11, you'd be getting a much better sub. If you can squeeze out $50 more from your budget, get two of them and run dual subs
post #8 of 12
+1
A guy I work with asked me for a suggestion and I told him about this sub the last time they were on sale. He loves it. The bass is deep and clean for a single 10" driver. At $200 it's pretty much a steal.
post #9 of 12
The VX 10/11 is only suitable for rooms up to about 2000 cu. ft.
Originally Posted by JimWilson View Post
+1
The Newegg link above shows a sale price of $299.00. Is there a special promo code?
Ian
post #10 of 12
Here's the correct link. That other one is actually an "auto link", which the forum puts in for you if recognizes something. They generally point to ebay for some reason - perhaps there's an agreement between AVS and ebay.
post #11 of 12
Ian
Note that you must register at newegg first and then you will be allowed to enter code EMCNEJE246 to get the Energy S10.3 for $199.99 and this particular sale ends on May 21.
post #12 of 12
I second the dual sub recommendation. spend the extra $50.
