Hi All...
Well, look at me, asking the community for help. Hey, we all need help sometimes.
Here is my issue that I am seeking guidance on.
MB = Gigabyte GA-880GM-D2H
Processor = AMD 6 Core (Forget the name off hand.)
RAM = 8 GIG
OS = Win7
Issue: Machine just stops responding at random times. I mean, just stops. Screen freezes and that's it. Need to hit reset.
This machine is used for automated tasks only such as home security camera recording (Blue-Iris), CrashPlan blacking up of a unRAID NAS, weather reporting (Davis System) and a few other things. So it is not like I am working on it etc. It just runs.
I have also had happen to me a few times that when I go to reset the machine, when it goes to reset, it powers off. (Yes, I hit the reset button.) The only way to turn it on again is to power off the PSU on the back and unplug it. Then after a few seconds, plug it back in, power on, and then power on the PC. Boots up just fine.
I have also had the same above power issue when telling Win7 to restart. It will power off when it goes to restart.
I have turning off programs that are running (Programs I have never seemed to be an issue mind you.) And even have left the system screen up showing the programs that are using CPU, Memory, even Disk so I can see if maybe something was running crazy on RAM, CPU or anything at the time in locks. Looking at that on the screen after it locks, nothing looks strange or out of what I would expect.
So, I am left, I think with hardware. But what part?
PSU? Motherboard? CPU? (Though the fan seems fine on the CPU)
Has anyone run into this in the past and can give me a direction or anything to try?
Thanks all.
RAM = 8 GIG
OS = Win7
PSU? Motherboard? CPU? (Though the fan seems fine on the CPU)Has anyone run into this in the past and can give me a direction or anything to try?
Thanks all.
Still not sure HOW the bee got in. System is in a rack in the basement.
