Originally Posted by mark haflich
Using different colored phosphors would eliminate the need to split a white diachromatically but you would still need polarizers in the colored beam light path if the chips are LCD or reflective LCD. Second while the laser itself has long life, the phosphors are consumables and the various phosphor colors are at rather fixed color points and those points are not extremely saturated points. So you might have to filter the light coming off the phosphors to get wide chromaticity points and filtering eats up light. Remember our CRT front projectors and the narrow color space of those days. green had to be filtered, Red needed to be filtered but couldn't be made correct without eating up too much light. And the blue phosphor was so limited in light out put no filtering was possible. The best solution is to have the laser or lasers generate the chromaticity points needed for the widest color space.
I totally agree. I do wonder how difficult it will be to get to the substantially wider color space, as defined for Ultra-HD by ITU rec. BT.2020, when using conventional UHP lamps and how much the projector's lumens output would be impacted when operating in this mode (as compared to rec. 709 HD color space - see below). Do you know what the color points are for widest available color space setting on your VW1000es?
Edited by Ron Jones - 5/19/13 at 7:50am
