Hello,
While there are certainly going to be aspects of the Posts that not everyone will agree with, I would hope that all agree that the 5009 has more than enough power to drive Klipschs. Even a really cheap 25 Pound AVR can drive most any Klispch 5 Channel Speaker System to Reference Levels due to their efficiency owing greatly to being Horn Loaded. By that same token, many do find Klipschs to be somewhat bright regardless of Amplification.
It is interesting that it appears the same Speakers did not seem to be bright when using a TX-SR875. I agree with the Posters who have postulated that perhaps it is the Audyssey XT32's far greater Filtering that might be causing this perception. It might be worthwhile to turn off Audyssey just to see if that is the case. This can easily done just by engaging Dolby Volume as whenever it is engaged, all Audyssey Processing is turned off. Also, I believe that Audyssey Dynamic Volume and Dynamic EQ are turned to on by default and might be worth turning off prior to disengaging XT32.
Regardless of the reasons why, I do hope the OP can again be pleased with the sound of his HT. The 5009 has plenty of power. Heck, even the TX-NR609 output around 90 Watts into 5/7 Channels when Bench Tested and does not have near the Amplifier Stage of the 5009.
Cheers,
AD
Cheers,
AD
