AVS › AVS Forum › AVS Forum Information › Forum Operations Center › token has expired
token has expired
post #1 of 3
when ever I perform a search, or try to post in a forum I receive the message
Your submission could not be processed because the token has expired.
Please push the back button and reload the previous window.
Hitting the refresh button does not correct this. Logging out and back does not either. This happens with both Firefox 12 and IE9 daily.
The only work around I've found it to log out, delete all cookies, close the browser, restart the browser, and log back in. Besides being time consuming, I'm losing tokens which keep me logged in to other sites.
Is there a setting where I can prevent this?
thanks
post #2 of 3
There's no setting on the forum to prevent this. It's a browser issue where they aren't handling cookies correctly. Odd that it's happening on both. Does it also happen on other machines?
post #3 of 3
I checked all 3 pc's here, all are the same. I installed Chrome on 1 of the pc's, but will not be able to tell until tomorrow if this persists as it happens after a day passes without accessing AVS on the other browsers.
thanks Mike
  Back to Forum: Forum Operations Center
