I recall reading ages ago that scaling must always be done with progressive frames. So for example, if you're sending 480i to a processor and then outputting 1080i to your display, the processor will deinterlace to 480p, scale to 1080p and then re-interlace to 1080i.
Is this true? I'm wondering how significant the consequences of poor deinterlacing are when considering the above process. Even if the processor does a fantastic job of scaling, if it doesn't have good cadence detection, then it will stay in 'video' mode, thus reducing the overall resolution of the scaled image.
Further to that, if its video mode is also poor, e.g. it introduces lots of jaggies, then presumably these jaggies will remain as artefacts in the image even when the output is 1080i, because those artefacts will become an integral part of the image as far as the scaling engine is concerned.
As an example, I send 1080i from my satellite box to my Edge, because otherwise I would have to wait about 10 seconds for the Edge to re-sync every time I switched between an HD channel and an SD channel. But since the sat box is scaling from SD to 1080i and probably doesn't contain a decent deinterlacing/scaling solution, then I'm wondering how much image quality I'm losing through this process?
Thoughts anyone?
Thoughts anyone?
