AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma ml500. anyone who owns 1
post #1 of 16
i am new to these forums. and i am interested in the Optoma ml500. and i am wondering if anyone who has it uses it with a 100 to 120 inch screen. because i wanna know the picture quality. any other info can help. thanks.
post #2 of 16
I used one with a da lite 2.4 HP screen that was 119in. To me the projector was not as sharp as i wanted it to be in the first place, but it was acceptable. I would go over 106in without a HP screen. Its very doable up to 140in with a HP screen and up to 92in with a basic white matte screen
post #3 of 16
well i would be at about 100 inch's. and the videos i have seen are mostly at 100 and the picture is pretty dam good.
post #4 of 16
It would be too dim for my taste, unless the room is dark colored. But I'm sure many use it with 100+ white matte screens
post #5 of 16
well the one video i saw the guy had in at 100 inch's on a favi(about 120 bucks) and it looked impressive. and the other guy got a piece of panel at lowes and used movie goo on it and it look very impressive as well.
post #6 of 16
I say go for it, you can get a 100in Elite pull down screen for $80 the last time i checked for one
post #7 of 16
yeah they seem to be anywhere from 80 to 160. is there one is particular? and also. i am getting ready to make a thread about this(assuming anyone ****ing repsonds lol). what might be the best HD 720p or higher projector that is around 700 or 800 bucks? usually one that has a lamp life around 5000 hours? i know the size is bigger for those and the picture is a minor but nice step up.
post #8 of 16
I had the Optoma ML500, then I switched to the Acer H5360 which cost me $400. I prefer the Acer because the lamp life is long at 5000 on eco mode, and the picture is so much brighter. The ML500 gave me 380 lumens, while the Acer is at 1500 lumens at best mode and its 3D. A big difference, IMO. I also have a $8K JVC RS55, and I still liked the picture quality of my Acer. I use it has my PC monitor, for cable, PS3, etc... Except when I'm watching blu rays or 3D blu rays, since my JVC is in another league. But surprisingly, it does well with 720p scources compared to the JVC. The Acer H6500 is $800 and rated at 6000 on eco mode, plus its 1080p. The Viewsonic Pro8200 is another $800 1080p projector with a 6000 lamp life.
The thing about using Eco mode is that it will be best to keep the screen size under 100in if you want to use eco mode for the extra long lamp life or get a HP screen. I have both, a neutral screen that is 100in and a HP screen that is 119in. Its like the best of both worlds. You can always find deals on used screens, which are good to buy IMO. I bought like 5 used screens and never got burned doing so. You can probably find a HP pull down screen for $200 used but it will cost you 500-600 new. I personally think the HP screen is the best screen and many use them with projectors that are $20K+.
post #9 of 16
Here is pictures from my Optoma ML500 with the Da Lite HP 2.4 screen
post #10 of 16
hmm those sound like good prices for good lamp life. whats they replacement bulb prices? and i assume there easy to install?
post #11 of 16
Here is from my Acer H5360
post #12 of 16
I know the Acer I have is about $150, but I don't know about the other ones.
post #13 of 16
If you want to maximize your $1000 budget, I say get one of the 1080p projectors and a nice screen. I have a Favi screen and I don't really like the material and its cheaply made. The best screen I have is the Screen Innovations 4K screen, which is a $2000 screen and its just made beautifully. But I still prefer my Da Lite HP screen over the SI screen. I also have a Carada screen, which is a really nice screen also
post #14 of 16
well i might go that rout. i will look further into it.
post #15 of 16
i forgot to mention thanks for the screen shots. there always nice to look at. lol not to mention all the dam videos.
post #16 of 16
i forgot. the acer 6500. its got a nice price tag and hours on the lamp. but there are no videos what so ever for it. you know where any videos or screenshots might be?
