AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How good is the Integra DTM 5.9 receiver?
post #1 of 15
Hi everyone,
How good is the Integra DTM 5.9 receiver with a pair of B&W 686 speakers?
post #2 of 15
Bump:
Sorry for bumping my thread.
Does everyone have the answer to my question? I'm sorry to ask again.
post #3 of 15
Its ok as long as you know its limitations. It isn't rated for 6 or 4 ohm speakers. I'd look at the Harman Kardon 3390 or 3490. Both are rated to 4ohms - and usually are cheaper. I've owned a 3390 for about two years and use it in my bedroom 2 channel setup. It works flawlessly - the only rub I have with it is its very large remote.
post #4 of 15
It's not going to work since it's not rated at 4 or 6 ohm speakers? The shop I want to buy it from recommended it to me.
post #5 of 15
Would this work better? A Marantz SR4023 receiver with the pair of B&W 686 speakers? I was thinking that the Marantz receiver can handle what you explained about the ohms?
If someone has the answers with Marantz, and B&W then please reply.
Thank you,
post #6 of 15
The Onkyos / Integras are manufacturer rated (designed) for speakers with a low impedance down to 3 Ohm. This should meet most speaker impedance (4-8 Ohm) available.
post #7 of 15
I'm confused. Are you trying to say it will work, or it won't work? I'm not understanding. I learn slow, so there is no way for me to understand.
post #8 of 15
Sorry, but i don't know the specs for the B&W speakers.
But as stated the Onkyo and Integra AVRs are generally specified (and stable) for impedance values down to 3 Ohm. You might check the data sheet for the B&W speakers though, to make sure it fits.
Most modern speakers (with some rather exotic exceptions) are defined as 4-8 Ohm mean value, which would fit.
post #9 of 15
Integra/Onkyo list very few AVRs or stereo receivers as 4ohm capable. Integra's own website shows the 5.9 as being rated for 8ohm speakers only - check the specs under 'features' - neither the 4 or 6 ohm spec is checked off - meaning it isn't recommended for those speaker loads - meaning the amp section may not be as good as other stereo receivers. Both of the Harman Kardon receivers I mentioned above are 4ohm rated.
B&W speakers are almost always 8ohm - as is the 686. The Integra 5.9 is pretty much an Onkyo TX-8555 IIRC. At any rate the Integra should work fine for those speakers. As would the Marantz 4023 - or just about any other stereo receiver you might want to buy. I mentioned the lack of 4ohm rating for that Integra since you might want to buy some 4ohm speakers at some point in the future.
post #10 of 15
So, what your saying is that the B&W 686 speakers won't work on that Integra Receiver, well, it won't be recommended, but the B&W 686 speakers will be recommended for the Marantz 4023 receiver?
Am I understanding that correctly in basic short words?
post #11 of 15
It has been stated numerous times before that both Integra and Onkyo have designed their amps for 3 Ohm minimum although not explicitly stated in their data sheets.
post #12 of 15
I'm really so sorry, but I am not understanding which means I am very confused. I'm assuming you guys would recommend, or don't recommend it? I do appreciate all of the info, but I'm not understanding the info.
Assuming it's not recommended for the B&W 686 with the 5.9. Then would or wouldn't it be recommended the B&W 686 with the Marantz SR4023?
post #13 of 15
Nothing to recommend but just saying, that it is technically possible.
The choice is yours though.
post #14 of 15
What exactly would happen using those speakers with Marantz SR4023 stereo receiver. I'm guessing it would blow out the system?
The guy at the shop recommended that to me. I hate to throw member names into this thread, but it was that William user who referred me to that shop based on my first thread.
post #15 of 15
From the B&W website - the 686 is rated 8 ohm with a minimum of 5.1 ohm so it should be absolutely fine with any receiver sold. The only issue I see is that this particular speaker is less efficient than many as it is rated at 84 dB but still it is claimed that an amp with 25-100 watts is fine. Just be aware, this speaker does not do low frequencies well and will require a subwoofer for most uses.
