Hi
I am connecting a new hdmi connector.
Do not have the old piece with the attached wires anymore.
Maybe a stupid question.
on the fron view of the female hdmi conn. the hot plug is on the left side no 19 on the upper side and tmds channel 2 begins on the right side on nb 1. with the wider section on top.
When do I begin on the rear side should I connect the Hot plug nb 19 on the same side , now on the right side and the tdms 2 on the left side?
It should go straight acording my opinion as a technician told me I should turn them to the other side, for then it will not go straight .
I do have literature about this , see under for a stetement .
It's not necessary to understand what each wire is for, but it is important to understand which wire goes to which pin. If you make a mistake and wire the wrong wire to the wrong pin, you risk damaging your components. This diagram shows the pin layout, as if you're standing in front of the connector. The wider section of the connector is the top of the connector, and contains the odd pins 1 - 19. The lower section, the narrower part of the connector, contains even pins 2-18. Make sure to keep these locations straight when looking at the HDMI connector from the reverse side.
Appreciate your thought and maybe a view from the back of the connector .
God bless you
Bob
God bless you
Bob
