There have been a bunch of threads with folks trying to calibrate there high end sets and projectors with D2 meters and the like. These meters are cheap and folks want to use them with the HCFR to learn how to calibrate. Unfortunately, even new D2 meters are not really accurate enough to use and expect good results.
Yesterday I calibrated a Mitsubishi WD73C11 RP set for another AVS member who had used his New (couple of month old) D2. The idea was when complete he would do a profile run with the HCFR software and my i1pro so he could profile his meter.
After resetting the input I would be working on, I check several inches of the screen to verify uniformity. Then I hug the i1pro, C6, and D2.
I profiled my C6 since that is what I would be using to do the gray scale, then ran 4 Pre-Cal captures to see what the d2 looked like
Here is a link to the word doc with the screen prints of those captures.
Screen Captures of i1pro, D2 an D2 profiled from i1pro
I did not check the D2 at low light levels, just did the pre-Cal capture.
As you can see, unprofiled even using the proper screen type in Calman, the New D2 is really far from anything resembling accurate.
Hope this answers some questions as to "Is the i1 display 2 or LT good enough" ..
