Just moved into a new house and setting up living room HT (among other things) before starting on dedicated HT.
Please forgive the horrible phone pics but you can see the built in entertainment center I am working with...
Bought two sets of bookshelf speakers. Energy RC 10's with RCLCR and then I saw the KEF IQ 30's with IQ 60 center and loved the look so I ordered those too. I will try them both and send back my least favorite.
I ordered the Home Theater Direct HD 65AIM's for rears. You can see in the pic that my in Ceiling rears are about 5 feet behind the listening area and I liked that they are angled 18 degrees and have adjustable tweeter...
My receiver is a Yamaha RX-V665 and I have a 10" Klipsch sub.
My fronts and center will sit on the shelves as close to listening level as I can get but my question is regarding the sub...
The sub is short enough to sit on one of the shelves, or I can put it on the far left next to the entertainment center but it will be just outside of the listening area.
Any help on sub placement would be greatly appreciated.
Pat
Pat
, as they're probably somewhat front-heavy. Also avoid placing them in the exact center of the shelves, which may result in stronger resonances--move them closer to the TV. If they sound OK to you when compared with how they sound, say, when placed at the edge of a table, then great, otherwise you may have to line the shelves with something that absorbs sound. Speaking of which, if your floor is hardwood, you may want to consider placing a rug in front of the entertainment center, as reflections off a bare floor can often be harsh; even if the speakers are mounted high enough to avoid this, it is still helpful to cover at least one side of the room with something that absorbs sound and thereby diminishes echoes.
