AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM6200 Cinema 3D Smart TV Owners' Thread - 2012
Official LG XXLM6200 Cinema 3D Smart TV Owners' Thread - 2012 - Page 6
post #151 of 160
1080p mkv files are working fine on the 65LM6200, I stream them wirelessly via Plex.
post #152 of 160
Can someone please tell me what is the default value for the backlight in Standard mode? I think I may have change it on the service menu... is it 75?
post #153 of 160
Originally Posted by Rudy1 View Post
You may want to try the WD TV Live: http://www.wdc.com/en/products/products.aspx?id=330
I've been using one of these for almost two years now. The latest firmware is a bit buggy, but more than likely if you purchase one it will not have the very latest firmware on it. And if it does, the WD Community forum has specific instructions for rolling back the firmware on these devices.
Thanks Rudy1!
I'm gonna try to stream via Plex and will revert...
post #154 of 160
Says "File is Invalid" ???
post #155 of 160
Are you using the built-in Media Link app in the TV?
Edited by THe_Flash - 11/18/13 at 4:05pm
post #156 of 160
Hi, I got in the service menu of the 47LM6200 and I'm not sure if I changed the Backlight in Tool 6 where it says STD, can you please tell me is the default factory value for the Backlight in Standard picture mode? is it 75? Thanks..
post #157 of 160
New Tweaktv settings
LG 47LM6200
Click here for other LG models
User Menu Settings
Picture Mode
Picture Mode : Expert/ISF 1
Aspect Ratio : Just Scan
Color Temperature : Warm
Picture Settings
Backlight : 28
Contrast : 90
Brightness : 56
Sharpness : 10
V Sharpness : 10
Color : 50
Tint : 0
Expert Control
Dynamic Contrast : Off
Expert Resolution : Off
Color Gamut : Standard
Edge Enhancer : Off
Color Filter : Off
Expert Pattern : Off
Gamma : 2.2
White Balance : Factory default
Color Management : Factory default
Picture Options
Noise Reduction : Off
MPEG Noise : Off
Black Level : Low
Real Cinema : On
Motion Eyecare : Off
TruMotion : Off
post #158 of 160
If you look at the 47, 55, and 65 models the only variance on TweakTV is the backlight settings. The 65 doesn't even use the same panel as the 47 and 55, it's difficult to believe the only changes needed would be the backlight.
post #159 of 160
but look okay, which picture settings are you using?
post #160 of 160
I started with the 6700's color managment settings from lcdtvbuyingguide.com, then used the Disney WoW disc to do color, tint, and the greyscale. I don't know about anyone else's findings, but if the contrast is not set to 100 on my 65" the whites will clip.
A setting of 90 seems really low for the 65" even given that there are variations between sets.
