AVS › AVS Forum › Display Devices › Display Calibration › Deep Color Test Pattern
Deep Color Test Pattern - Page 2
post #31 of 35
does the PS3 output YCbCr 4:4:4 or YCbCr 4:2:2 when playing BD movies?
and I know I asked this before, but does it matter whether the Deep Color setting is on 'Automatic' or 'Off'?
post #32 of 35
It plays the mode you set it to play as I recall... haven't looked at my PS3's menu in a long time though, but I'm pretty sure there were 4:2:2 and 4:4:4 options... though if you select 4:4:4 you'll get 8 bits and if you select 4:2:2 you'll get 12 bits by default unless you change the bit depth somewhere else... this is a little known or understood factoid that Jim Peterson (Lumagen) has posted in at least 1 thread here.
post #33 of 35
Ps3 doesnt have the option to choose between 4.2.2 and 4.4.4, it does 4.4.4
post #34 of 35
This is true.
I've verified this with my receiver and a Lumagen.
post #35 of 35
thanks, I asked because there is no choice between 4:4:4 and 4:2:2 and it's not labeled as either
