AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Receiver for Pioneer bs21
post #1 of 6
Need advice on an amp or receiver for the pioneer bookshelf and sub. 2.1 for now but needs optical in for Apple TV. Unfortunately price is a major factor right now. Coming from Kef and Sony ES receiver I have decent standards. Small room of only 10X10 with wood floors. Looking forward to the expert opinions.
B.Ellis
post #2 of 6
B.Ellis
Budget? Required features? Use?
If you're in a big metro area I'd look to craigslist for an adequate receiver. You don't need much based on your posted requirements.
post #3 of 6
Just check accessories4less for a cheap refurb with all the features you need.
post #4 of 6
Great response, thanks. Went with the Denon 1312 for $119
B.Ellis
post #5 of 6
I think you would appreciate the 1612 a little more due to it having Audyssey room calibration software. Unless your budget is real tight spend the extra money, you'll be glad you did.
post #6 of 6
Changed it to the 1612 with free ipod dock at accesories4less
Thanks for the tip
B. Ellis
