Hello:
I was debating on going between an epson 3010 and a 5010 and decided to go with the 5010.
I am thinking it would be easier to upgrade my screen at a later time than the projecter. If I'm just plain wrong please let me know.
So in going with the bigger projector I am moving some of my screen budget to the projector for now.
I am looking for something in the $500 range or under if viable. If there is a big difference I might be able to go a bit over.
I am thinking 120" or 133" size. A fixed frame screen is fine as it is a dedicated room. I will be mostly watching 3d.
The main seating position is 14 feet from the back wall where the screen will be mounted.
I currently plan to ceiling mount the projector at around the same distance back as the seating position. I do have other mounting options if needed. I could do a back wall shelf mount as well which would be about 20 feet away.
If any additional info is needed just let me know.
Appreciate any help or suggestions.
