Hello ladies'n'gents!
Hope I am posting this in the right place...I got a projector that can do side-by-side split screen with 2 sources...which will mainly be used to watch sports/play video games at the same time. However, my projector apparently does not support 2 HDMI sources at once, and 1 component is already used, so that leaves my VGA input if I want to do 2 HD sources at once. Unfortunately, I can't tell my projector (Epson) that the component source I'm feeding it through an adapter is YPrPb rather than RGB...so I'm off to get a signal converter.
Has anyone used a component-to-VGA converter? If so, what should I look for? Are there any you recommend?
Thanks so much for your time!
