I have a CM4228HD mounted on a stucco wall under my eves. I have it screwed right into the stucco wall. I'm in the process of adding a second story onto my house and will be moving it higher. I'm planning to mount it under the eves on the new 2nd story & screw it directly into the wood siding, with no antenna mount. The towers I'm aiming for allow me to mount it flat against the wall.
My contractor is a licensed electrician and has bought a spoil of ground wire, but he said he has never grounded an antenna before. I want to make sure he grounds it correctly. Can I use a coaxial cable grounding block? Or do I connect it somewhere on the antenna itself?
