AVS › AVS Forum › A/V Control & Automation › Home Automation › HAI - Philips Pronto integration
post #1 of 2
Does Philips Pronto still support integration with HAI? Google search is yielding results from 2009. I can still find some material on the HAI site but the Philips links with regards to the integration are invalid and I can't tell if Philips still supports the integration.
Has anyone done this recently?
In the worst case, if the integration is no longer supported, does anyone know how to control HAI lights with a universal remote such as Pronto? Do I need to get something from HAI?
Thanks in advance for your help.
post #2 of 2
What are you using for Phillips hardware, which remote do you have and are you using a base station? What Hai controller do you have?
  Back to Forum: Home Automation
