Originally Posted by iballin88
ahhh ok I think i get what your saying.. sorry i lack knowledge in this stuff but learning , so what you mean is say my default values are abit different then anikuns, are picture is still the exact same at default, thus why using number of clicks is better because of the difference in our defaults(which match picture) to make the picture match in our end values because are values started out different ? basically closes the gap
Hmmm
Well, it seems someone else did the clicking method for anikun, so I'm not so sure. If that's the case he probably just matched anikun's settings. I'm no expert, but to my knowledge the SM values are not the same for every set, so setting someone else's values aren't going to give you the same picture. However, I figured that the number of clicks would have been more accurate, but that's only if anikun was the one doing them. I guess you should just try to plug in the values and see what you get.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
