Originally Posted by damag0r
Well I was originally using Anikun's settings, which seemed good enough... but after 1000 more hours of aging the panel seems to have become quite uncalibrated.
For reference I was using my Dell U2412M which is using the settings and ICC profile from TFT central. It's been verified to be very close with a meter, and might have been tweaked slightly. I think once I used TFTcentral's ICC profile on the U2412M it was so close when it was tested with a meter we just left it alone or only made very minor changes. Anyway.... I just displayed the same image on both screens and tried to get the UT50 to look as close as possible to the U2412M. My changes did take the reds off a little but everything else is so much closer. The colors were a bit oversaturated after my WB changes too, but simply taking the "color" setting down a few notches fixed this.
Also, why such a big "no no"? I have what all the original values were, so I am able to change it back anytime. Plus I didn't mess with my Cinema/Warm2 settings which are still at what Anikun posted. I only changed the Custom/Normal WB.
From what I've read this set is a lot different than the VT50 and "Warm 2" is closest, but it looked way too orange to me compared to my U2412M.
Edit: If anyone cares here are my probably horrible by eye settings with 1249 hours on the set (they look great to me though):
Normal Color Temp Using Custom Mode (Anikun07's original settings in parens):
R-Cut: 7C (7F) - dropping this seemed to help a lot with the "magenta" blacks
G-Cut :60 (6A)- seemed too high on my set at least w/ 1200+ hours on it
B-Cut: 60 (60) - changing this at all only seemed to makes things worse, so I instead increased the B-DRV
R-DRV: EF (EF) - no change - which is likely why I see some very slight skewing with the reds sometimes
G-DRV: EE (FF) - this FF seemed WAY too high on my set... at least with 1200+ hours on it
B-DRV: 9F (97)
All Cut: 7C (7F)
All Drv: EF (FF)
Contrast: +84 (same)
Brightness +56 (same)
Color: Anywhere from like 42 to 47 (I usually keep it at 45-48 because I like that slightly 'over-saturated' look, but it depends on the source content).- Anikun's was originally 48, but 48 definitely seems more "saturated" after I made the white balance changes in the service menu.
Tint: 0
Sharpness: anywhere between 0 and +15
HDMI: standard
content type: off
Everything else OFF
B-DRV: 9F (97)
All Cut: 7C (7F)
All Drv: EF (FF)
Tint: 0
HDMI: standard
content type: off
Everything else OFF
You realize any change you make to any cut or drive impacts the others and the drvs impact the cuts and vice versa ? Green has the most effect on gamma so hard telling where that is at now and the all values impact all red green and blue at the same time. In the end its your set do as you wish. If you're that confident in your methodology post this over on the display calibration forum and see what kind of responses you get. This has been attempted before here and the settings when measured with a meter where no where close to being accurate.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
