AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Help Me To Choose Budget HDTV
post #1 of 4
Hello everybody.
I am looking for a very good HDTV for my bedroom.
my 1st preference is picture quality in HD as well as SD.
because I am from India and HD channels are not big in numbers.
Most of the channels are of SD quality, so looking for a good HDTV which can give good picture quality to SD source also.
here are some models I've note down after searching at various shops.
LG 32LK450 (LCD)
LG 32LV2130(LED)
Panasonic 32U30D(LCD)
Panasonic 32X33D(LED)
Samsung LA32D550(LCD)
Samsung 32EH4000(LED)
Sony Bravia 32NX520 (LCD)
Sony Bravia 32CX420 (LCD)
I am actually confused about whether to buy LCD or LED. Is there any big difference between both in the range?.
It will be a very big help if you guys can help me out.
Thank You
Regards.
post #2 of 4
Originally Posted by invinci View Post
Hello everybody.
LG 32LK450 (LCD)
LG 32LV2130(LED)
Thank You
Regards.
if you can get the LG LK450 with the S-IPS panel, it's a great value; I have the 42" version and the PQ post-cal is very good
post #3 of 4
Thank you for replying mate.
how to know whether it has S-IPS panel or not?
cause I think In India it is hardly available or rather not.
any other options besides that?
Thanks again mate.
Regards.
post #4 of 4
Thanks again mate.
Regards.
there should be a "Y" in the fourth letter/digit of the model code and the pixels should be chevron shaped (<<<<<<) if you look at them very closely with a loupe or magnifying glass
