AVS › AVS Forum › Video Components › Home Theater Computers › Live TV Not Loading on MCE Startup?
post #1 of 6
I have changed the shortcut to include /mcesuperbar://tv?live=true but MCE is still starting in MediaBrowser.
Why is it doing this? MB is not in the startup folder either, I checked that already.
post #2 of 6
100+ views.. Does anybody know how to fix this?
post #3 of 6
That only makes the change active for the shortcut. So when you actually click on the link in the start menu or the shortcut, WMC will start on live TV. If you use the green button on an MCE remote or when Windows starts, it will not default to live TV.
post #4 of 6
Okay, so how do I get it to default to Live TV when loading it that way? It seems that when I load it buy clicking on the WMC icon pinned to the task bar it still loads into MB.
post #5 of 6
Well I just did a system reboot and it is not loading into MB but not fully into Live TV either. It is at the WMC menu with "Recorded TV" highlighted.
post #6 of 6
I don't have MB loaded so I'm not sure how that affects things. I'm at work right now so I don't have access to the instructions I used to make the change.
