I think I have a couple options as to how I want to upgrade this year, and it depends on whether or not my current desktop is still up to snuff.
My original plan was to get a new desktop and set it up as an HTPC for videos and gaming, and then somewhere down the line get a new laptop (preferably a MacBook) for work. I currently use one desktop for both.
I just found out however that I can already connect my current desktop to my TV and pretty much convert it into an HTPC if I can just get my hands on a wireless USB mouse and keyboard (the system doesn't have bluetooth).
It's a five-year-old system with the following specs:
Intel Core 2 Quad Q6600 3.2GHz
3GB RAM
HD6840 1GB VRAM (I added this a year ago)
Vista 32bit
I just tried it out a bit on the TV and it seems to be powerful enough to run almost all PC games in 1080p. The sole exception is The Witcher 2 on which it can still maintain 30 frames per second in 1080p (and probably Crysis). I just tried running RAGE and Skyrim and they book look and run fantastically. Are those specs gonna be enough though when Next gen console games start raising the bar?
So:
Option 1: Keep my current desktop as an HTPC and compliment it with a MacBook Pro this year.
Option 2: Get a new desktop as an HTPC for next gen gaming, keep the old desktop as a work system, and get the MacBook Pro much later down the line.
Also, I'd like some suggestions for a wireless USB mouse and keyboard regardless.
3GB RAM
Vista 32bit
So:
