My grandfather is not able to do anything with the slightest complexity on the computer so I need help figuring out how to hook his computer up to both his monitor and his tv at the same time while displaying sound and video to both.
I purchased a Radeon HD 5450 with the hope that I could run the HDMI with sound to the TV and the DVI to the monitor using his computer speakers. I didn't realize that it was not possible to run the onboard audio at the same time as the audio through the HDMI cable. In order to get sound to the tv you have to change the sound card in Windows XP to the Radeon which eliminates the computer speakers. He will not be able to switch sound back and forth that way so I thought maybe an HDMI splitter would work. I bought this one from Monoprice. http://www.monoprice.com/products/pr...seq=1&format=2
It did not work. The picture did not display in the correct resolution in either the monitor or the tv and it didn't transfer the sound to either.
Some basic information.
Windows XP
Radeon 5450
Panasonic S1 1080p
Asus monitor which is 1920x1200
If I could get the picture and sound split with the correct resolutions then I could just use the radeon and the computer monitor's speakers and abandon the powered speakers he has hooked up. (he would be glad to be rid of the extra cables and doesn't understand in this age of wireless why there have to be so many cables hooking up the computer)
Any ideas would be appreciated and any more information you might need I'll provide. Remember that the solution has to be something that doesn't involve him having to do anything more technical than throwing a switch. Thanks!
Windows XP
Radeon 5450
Panasonic S1 1080p
