I was checking out the video black level on my new build to see if it was OK. The HTPC has an ECS H61 mobo and Intel G620 CPU & is connected to a Sony HDTV via HDMI.
I used the THX Opimizer setup that was on a standard DVD & could not display the THX drop down shadow or more than 7 shades of gray/black no matter how I set the HDTV's black level / brightness. I went into the Intel Graphics properties & changed the Quantization Range from Limited to Full but it made no difference.
I used the same DVD on my Blu-ray player connected to the same HDMI connection on the HDTV and I can adjust the HDTV to display all 10 blocks of shades of black & the drop shadow. And IIRC my standard DVD player also would allow blacker-than-black.
The only variable is the HTPC. The 7 shades of black from the HTPC appear to match the 7 shades of black from the Blu-ray player with the HDTV properly adjusted. IOW I'm not losing anything from the HTPC.
But I am curious why the HTPC is not even able to output a B-T-B signal.
Is there another setting which controls that?
