Hello.
I have Samsung CRT model CL-21Z57MQ. I bought 2 years ago approximately.
The problem is that the input component does not work. This came from the factory.
I have tried various component devices PS2, Xbox 360, etc.. I plug it in and it looks good without any problem, but if I put it in progressive mode. The screen is divided in two and the same thing twice and so distorted and altered colors. You can not see almost nothing of the image.
So before you buy another CRT. I'll do my best to fix this. It's a shame, because everything else works perfectly and is also new.
By the way. Enter the Service Menu and set the factory defaults. It did not work. Do not change anything else.
I hope you can help me, thanks.
PS: Sorry my English is not my first language.
