Hello. I have been searching and searching for a nice speaker system for my computer/tv. I watch movies, play games and listen to music at moderate lvls. I really like the Audioengine 5+ speakers so far. I think they would be great for my Pc/music/movies. The Audioengine 5+ are powered speakers. this is something that is convenient for me at the moment. Im looking for a simple easy set up thats easy to move around. Say for instance i have my speakers with my sub woofer set up on my computer. Then maybe later that day i want to watch a movie on my tv. I would like to be able to move the speaker system and hook it up to it or just my mp3 player to the speakers and the subwoofer. Im leaning towards a Velodyne subwoofer but im open to more suggestions. Ive heard many good things about Velodyne and I was thinking about the Velodyne Impact 10. Its fits right around my budget. I was wondering if i could plug in the Audioengine 5+ to the Velodyne with no problems? Would it be a nice setup? In other words will it work with straight rca cables? Am i trying to set it up wrong? Or would the engineaudio 5+ and the Velodyne separately plug into my pc/tv? If so what cables would i need?
Attachment 247616
Attachment 247617
Audioengine A5+
Additional Specifications
2.0 powered bookshelf speaker system
Power Output: 150W peak power total (50W RMS/75W peak per channel), AES
Inputs: Dual 1/8 stereo mini-jacks
Outputs: USB type A (power charging only), RCA L/R audio (full-range, non-adjustable)
Voltage: 115/240V, 50/60 Hz manually switchable
Amplifier type: Dual Class AB monolithic
Drivers: 5" Kevlar woofers, 20mm silk dome tweeters
Signal to Noise: Greater than 95dB (typical A-weighted)
THD: less than 0.05 percent at all power settings
Crosstalk: less than 50dB
Manufacturer Specifications
Frequency response: 50Hz-22kHz
Input impedance: 10k ohms unbalanced
Dimensional Specifications
7" W x 10" H x 7.75" D
Velodyne Impact-10
Comparison Specifications
Maximum Dynamic Power (MDP) amplifier: 150W RMS, 250W dynamic power
10" forward-firing woofer (8.2" piston diameter)
High pass crossover: full range, low pass crossover: 50Hz - 200Hz
Frequency response: 32 - 140Hz +/-3dB
Acoustically neutral, down-firing ported cabinet design
5.6 lbs. magnet structure
2" dual layer copper-wound voice coil
Coated fiber cone
Inputs: RCA line level, LFE and speaker level inputs
Outputs: Stereo, left and right, speaker level
Phase: 0° to 180°
Auto on/off
Removable grille
LED power indicator
Dimensions: 12.75" W x 13.7" H x 14.4" D
The Audioengine 5+ are just a thought i had for this setup. I have heard nothing but good things about them. I even heard they throw enough bass that some people change there mind about getting a subwoofer with them but i wouldnt mind some nice lows. Since these are both powered i was thinking it would be easy to set up and move around the house. I know i can also go with non powered speakers but i would need a receiver correct? It seems like it would be more expensive to go that way. Please correct me if im wrong, but i would rather keep it simple to something like this and cut out the middleman(receiver). If anyone have any suggestions or advice i would really appreciate it. Thanks for stooping bye and reading my post.
Attachment 247616
Attachment 247617
Audioengine A5+
Velodyne Impact-10
Coated fiber cone
Phase: 0° to 180°
Auto on/off
Removable grille
LED power indicator
