AVS › AVS Forum › Audio › DIY Speakers and Subs › Graph overload! 5 drivers(Zv3,21LW1400,21SW152,LMS-R12,SA12) 4 Cabinets
post #1 of 15
Drivers:
18Sound 21LW1400
B&C 21SW152
TC Sounds LMS-R 12
Kicker SoloX
Sundown SA12
Sundown Zv3 18
Cabinets:
WiSub:
Generic ported:
Bass cannon:
WiEasy Sub:
Measurement rig:
Dell Lappy
PreSonus FireBox
Berry ECM-8000
Ashly FTX-2001
Tape measure
I'm working on sorting and uploading the graphs, this will take a minute there are 15 of them.
post #2 of 15
First up, Generic ported:
8.6cubes, 33hz tune, 18 or 21" driver.
21LW1400:
21SW152:
Zv3 18:
Composite:
post #3 of 15
Bass Cannon:
2.5 Cubes, 25hz tune, 12" driver.
SA12:
LMS-R12:
Composite:
post #4 of 15
Wieasy sub:
5.5cubes, 33hz tune, 18" driver.
Zv3:
post #5 of 15
Saved the best for last, the WiSub.
9.7 cubes, 31hz tune, 18 or 21" sub.
Zv3:
21SW152:
21LW1400:
SoloX 18:
Composite:
post #6 of 15
Discuss
I have found the 21LW1400 to be completely badass.
post #7 of 15
OMG!!
I bet your neighbors love you!
post #8 of 15
Originally Posted by Subjga View Post
OMG!!
I try to do it during the weekday when most aren't around
post #9 of 15
Increase the sweep until the woofers max out and regraph.
(if your neighbors will even let you).
I'd like to see which one cries uncle first and at what SPL.
post #10 of 15
How high was the noise floor while taking these measurements?
post #11 of 15
The amp tripped a couple of times when starting at 10hz. I didn't test with a KLR, I may do so next run.
There was a slight breeze, the SPL meter wavered between 20 and 30db when I wasn't doing sweeps. Not much I could do about Mother Nature unfortunately.
post #12 of 15
have you listened to the 21lw1400 vs. the zv3 with the big inductance hump eq'd out? impressions?
post #13 of 15
Which amp was that? (oh Ashly FTX-2001, nevermind)
Be careful doing 10hz on a ~30hz tuned port; I'd start at 200hz and sweep down to 30hz or so. Problem solved.
post #14 of 15
Discuss
Hmmmm, care to elaborate a little more
post #15 of 15
It is light, output that keeps up with the B&C, and isn't god awful expensive. It also measures the flattest of the bunch in the 2 cabinets it fits.
