AVS › AVS Forum › 3D Central › 3D Tech Talk › Optoma HD65 w/nvidia 3d vision
post #1 of 4
Hi guys.
I have been at this for a few days, and I have been unable to get this setup to work, has anyone here been able to do this. If so I would greatly appreciate any tips you could send my way. I'm running a 680gtx with new drivers I have the HD65 firmware updated, now I see 1080p signal at 60hz and 720p at 60hz.
There is no option in nvidia control panel to chance that to 120 Hz except to create custom resolution. I have the projector connected via dvi to hdmi adapter and I tried changing the projector drivers to Acer inf files, it seems to have helped in getting the 120hz as option but the outcome remained the same no 3d, I can't even pass the hardware 3d vision test. Please advice, Thanks.
post #2 of 4
Hey mate,
just wondering if you got any love with this?
I am trying to do the exact same thing however I have a Quadro 2000
cant get past the wizard either...?
post #3 of 4
I initially had problems but I resolved them by using a High Speed HDMI cable. YEs, Iknow all HDMI cable are supposed to be the same but for some reason using a regular one would only kick out the 120 to 60Hz. My setup is 430 GT, NVIDIA VISION, tmt 5 AND THE hd65. There is another forum that I started when I initally had problems and it was suggested that you needed to spoof the driver with the HD67 to trick the HD65. After I did that and used a Highspeed cable, all is well.
Here's the link to the instructions on how to get it working: http://www.avsforum.com/t/1382220/anything-else-needed-for-3d#post_21394644
post #4 of 4
what driver is installed for the projector? Did you try switching the refresh rate in windows?
  Back to Forum: 3D Tech Talk
