Originally Posted by
Jesse S
Lotta power. I only have about 3000 watts and my system goes louder than is usable (126db+).
What meter are you using?
Kanaris
What do you do with 8 LMS Ultras and over 56,000 watts?
You are looking at the 2-ohm spec (which the clones can't do), notnyt uses them in 4-ohm, so...
4400 x 8 = 35,200 watts (peak power)
notnyt
What are you going to do with all of those subs?
I'm not sure...
Right now I don't have enough amplifier power for even the 7 I'm currently powering, let alone the others.
Hence why I was looking into a FP14K (or 2+, depending on exactly how beefy/good they are; not sure until I try.)
um but, my room has serious phase issues (or something) cause I rarely break 122db with those 7, with an average of 110db, at least according to my CM-140. Which is loud, but I don't find it THAT loud.
My room is about 20% smaller than yours notnyt.
