AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Does the Panasonic S1 allow HDMI with RCA audio input?
post #1 of 3
My grandfather has an S1 and I'm wondering if an HDMI input can be used with any of the RCA AUDIO inputs so I can run an audio splitter from his computer to his TV while carrying the video signal with the HDMI cable. It would be awesome if so.
Thank.s
post #2 of 3
Yes you can connect the analog audio cable from the computer to the Red/White Audio jacks on any un-used Component Input or Composite Input, then you go into the settings menu and assign that audio source to any of the TV's HDMI inputs.
In settings, go to Audio > Advanced Audio > scroll down and hightlight the HDMI input he's using his PC on, then you can toggle through the choices and select which analog input that HDMI input gets it audio from.
post #3 of 3
Beautiful. Thank you!
