AVS › AVS Forum › Video Components › Video Download Services & Hardware › Netflix on PS3 credits squish
post #1 of 3
My Netflix app has started squishing the video into a little window as soon as the end credits of TV shows begin, with the majority of the screen offering to play the next episode.
I can't find the post that said how to make it go away. Anyone know? The only two button options shown onscreen are circle (which stops stream) and triangle (search). Square didn't do anything as far as I could tell. The pause button on the remote also doesn't work while this overlay is active.
post #2 of 3
It was mentioned in the Playstation forum here.
http://www.avsforum.com/avs-vb/showt...1#post22018801
post #3 of 3
Ah yes, that did it. Thanks.
